Impreza 2.0S
Impreza 2.0S
  • 3911
Răspuns: Impreza 2.0S
« Reply #160 on: June 01, 2014, 20:23:43 PM »
Da, cam interesant... Vad ca te bat rau de tot ganduri de modificari
  • 2813
Răspuns:
« Reply #161 on: June 01, 2014, 21:05:07 PM »
Cu Fab vorbeai, Catalin? :))
Pana una alta, filtrul, am pus din ala, cu restul nu cred :)))
  • 2813
« Reply #162 on: June 12, 2014, 11:59:42 AM »
maine ma duc sa`mi schimb difuzoarele de pe usile fata, si sa fac si antifonarea (doar fata). as fi vrut toate 4, dar no money for now. urmeaza si spatele + un dvd player eventual.
am vrut sa merg la Relu, am vazut recomandarile voastre, insa mi`a oferit un pret mult mai mare decat ce gasisem eu in alta parte, pt fix aceeasi operatiune si aceleasi difuzoare.
astea le`am ales http://www.car-sound.ro/difuzoare-auto/sisteme/focal/access-165-a1.html
Fab
  • 791
« Reply #163 on: June 12, 2014, 12:49:29 PM »
Foarte bune alegere la difuzoare, insa e pacat de ele daca le tii pe headunit-ul stock. Trebuie amplificate neaparat. Pentru antifonare ce folosesti?
  • 2813
« Reply #164 on: June 12, 2014, 12:51:06 PM »
o sa schimb cu siguranta si cdplayerul, insa nu acum. putin cate putin.
antifonarea si montajul o sa o faca tot firma asta de unde le`am si cumparat.
cam asa arata usa facuta de ei:
https://scontent-a-fra.xx.fbcdn.net/hphotos-xpa1/t1.0-9/10178148_641191989269393_3534521506964998339_n.jpg
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xfp1/t1.0-9/1609630_603524219702837_1765626542_n.jpg
nu prea ma pricep, sper sa fie ok. ma costa 300 ron montajul+antifonarea.
« Last Edit: June 12, 2014, 12:53:31 PM by moguai »
  • 2813
Răspuns: Re: Impreza 2.0S
« Reply #165 on: July 30, 2014, 16:07:45 PM »
De mic am fost fan Subaru...
« Reply #166 on: July 30, 2014, 16:11:31 PM »
Musca?De ce esti asa departe? ;D
  • 2813
« Reply #167 on: July 30, 2014, 16:17:58 PM »
 ;D ;D ;D ;D ;D ;D
acum 9-10 ani...ma interesau masinile, nu femeile.
« Last Edit: July 30, 2014, 16:23:47 PM by moguai »
« Reply #168 on: July 30, 2014, 17:04:48 PM »
Ciudat ??? ;D
  • 2813
« Reply #169 on: July 30, 2014, 17:35:45 PM »
nu e ciudat, ca acum e fix invers  ::)
  • 2813
« Reply #170 on: September 29, 2014, 15:49:41 PM »
pe lista de cumparaturi/schimbat:
2x bucsa bara stabilizatoare spate
2x rulment roata spate
+ verificat discuri daca s`au ovalizat (face volanul ca toti dracii la frana tare, la viteza mare)
ridicata pe elevator am vazut ca masca fata, spate si pragurile sunt terminate - julite, sparte, lovite + o aparatoare de noroi gaurita. casco scrie pe ele.
Fab
  • 791
« Reply #171 on: September 29, 2014, 17:30:53 PM »
Au inceput sa huruie rulmentii?
  • 2813
Răspuns:
« Reply #172 on: September 29, 2014, 19:03:18 PM »
De ceva timp, iar la service mi au zis ca ambii fac galagie...asa ca...ii schimb.
Ce altceva sa mai verific - ca sa dau de cap vibratiilor care mai apar uneori la viteze mari? Jantele clar desi le am verficat de 2 ori si nu au nimic ... altceva?
« Reply #173 on: September 29, 2014, 20:59:48 PM »
Ai schimbat vreodata ambreiajul?
  • 2813
Răspuns:
« Reply #174 on: September 29, 2014, 22:12:03 PM »
Da, a fost schimbat de dentista pe la 85-90000 km
« Reply #175 on: September 29, 2014, 22:58:59 PM »
Sa stii ca si la mine au aparut vibratii la viteze de peste 160 km /h fix dupa schimbarea ambreiajului.Cred,dar nu sunt sigur, ca si cardanul are o pozitie in care e echilibrat cu flansa spate.Si sigur la mine l au dat jos si l au remontat cum s a nimerit.Posibil ca de aici sa fie problema.Dar nici nu am apucat sa investighez.Precizez ca inainte nu vibra nimic nici la 200 km/h.
  • 2813
Răspuns:
« Reply #176 on: September 30, 2014, 11:07:41 AM »
Ai mama. 850ron 2 rulmenti. Pe orginal erau 1500...
Asta e...macar bucsile sunt ieftine (150ron 4 buc)
Fab
  • 791
« Reply #177 on: September 30, 2014, 17:51:40 PM »
Ce bucsi mai schimbi in afara de alea de la bara stabilizatoare?
  • 2813
« Reply #178 on: September 30, 2014, 18:14:21 PM »
doar alea 4 de pe bara (2 fata 2 spate) - asa am inteles ca sunt. am mai schimbat insa unele pe fata+o bieleta (sau doua) anul trecut in iarna dar nu mai tin minte exact care. (sper totusi ca mi le`a schimbat ca n`am fost de fata, dar de platit am platit)
o sa verific discurile daca s`au ovalizat, ca tot le da jos sa monteze rulmetul. din ce am inteles, nu e doar rulmentul in pachet, e si butucul, de asta sunt destul de scumpe. bine, SKF era mai scump decat ala pe original, 850 bucata  :o
la alte marci am vazut ca poti cumpara strict rulmentul si e undeva la 60 max 100 ron.
« Last Edit: September 30, 2014, 18:25:52 PM by moguai »
Fab
  • 791
« Reply #179 on: September 30, 2014, 18:18:21 PM »
Ce rulmenti ai luat?
