forester diesel resetare dupa schimbul de ulei.
Started by valiauto68, March 11, 2014, 09:15:33 AM
valiauto68
Silver member
Logged
salut.
Am cautat un subiect care sa ma ajute ,dar nu am gasit .
Am facut schimbul de ulei la un forester diesel. Am citit ca se reseteaza ecu astfel incat sa recalculeze indicele de contaminare a uleiului.
pe un forum am vazut asta :
It also said the oil replacement data 'should' be reset..
start engine
depress & hold brake peddle
turn rear demister on
turn parker/clearance light on
turn rear demister off
turn lights off
turn rear demister on (again)
turn parkers on (again)
turn lights off
release brake
the glow plug light should blink for 5 seconds to confirm reset has been successful
note - the above steps need to be done pretty quickly. i think you have a max of 4 seconds between each of the above steps.. If it fails, let engine idle for 30 seconds, turn off for 15 seconds and retry..
Cam cum s-ar traduce ? nu inteleg ce e ala demister si parker lights ?
sco
Scooby freak
Logged
Aldos
Platinum member
Logged
Salut.
Procedura asta se aplica doar la modelele EURO5.
Daca toti pasii au fost urmati corect, trebuie sa palpaie de cateva ori indicatorul de bujii incandescente.
valiauto68
Silver member
Logged
Multumesc, sper sa mearga , pentru ca testerul meu bosch nu vede valori actuale si nici nu face resetarea.
Masina are dpf ,deci sigur e euro5.
Axu
Gold member
My09 Forester Diesel
Logged
Nu este sigur ca este EURO5 daca are DPF. Toate modele Forester Diesel au DPF. Doar ca cele facute in 2008-2010 sunt EURO 4, iar cele facute dupa 2010, sunt EURO5.
Daca ai model EURO4 resetarea se poate face doar din soft, nu merge varianta cu "butonatu".
Ceva nu e bine oricum!
Aldos
Platinum member
Logged
Axu are dreptate.
Modelul EURO5 se fabrica incepand cu a doua jumatate a anului 2010.
Se poate verifica vizual dupa galeria de admisie daca nu ma insel (la EURO5 este facuta din alt material).
Cateva detalii aici: http://subdiesel.wordpress.com/boxer-diesel/car-model-overview/
Cel mai simplu insa este sa te uiti in cartea de identitate a masinii.
Ultimele 2 caractere ale numarului de omologare stabilesc norma de poluare.
http://www.buhnici.ro/2008/04/11/cum-stabilesc-norma-de-poluare-a-masinii-2/
