Sunt prea multe editii limitate pentru a face un poll in forum asa ca fiecare va trebui sa scrie care este editia limitata preferata. Si incep eu... Lupta stransa si aproape la egalitate de puncte cu Spec C Type RA-R... favorita mea este... tam tam tam tam tam taaaam!
Impreza S2042006 Subaru Impreza S204 Specifications
Chassis
Brakes F/R: ABS, vented disc/disc
Tires F-R: 235/40 ZR18
Driveline: All Wheel Drive
Engine
Type: Flat-4, Turbocharged
Displacement cu in (cc): 122 (1994)
Power bhp (kW) at RPM: 320(235) / 6400
Torque lb-ft (Nm) at RPM: 319(433) / 4400
Redline at RPM: n.a.
Exterior
Length × Width × Height in: 174.5 × 67.9 × 55
Weight lb (kg): 3196 (1450)
Performance
Acceleration 0-60 mph s: n.a.
Top Speed mph (km/h): n.a.
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
(http://img51.imageshack.us/img51/8371/imprezas20406.th.jpg) (http://img51.imageshack.us/i/imprezas20406.jpg/) (http://img822.imageshack.us/img822/4595/imprezas2040605.th.jpg) (http://img822.imageshack.us/i/imprezas2040605.jpg/) (http://img69.imageshack.us/img69/6060/imprezas2040602.th.jpg) (http://img69.imageshack.us/i/imprezas2040602.jpg/) (http://img824.imageshack.us/img824/427/imprezas20406inter.th.jpg) (http://img824.imageshack.us/i/imprezas20406inter.jpg/) (http://img63.imageshack.us/img63/7801/imprezas20406inter2.th.jpg) (http://img63.imageshack.us/i/imprezas20406inter2.jpg/)
eu prefer S203 ;) exista una in romania cu conversie la LHD facuta.
partea misto ca masinile astea vin cu multe piese de fabrica STI. si ciresica fiind turbina twin scroll. turbina care la delaer ca si piesa de schimb costa cat 3 turbine aftermarket normale.
nu spun decat atat 22B
(http://img819.imageshack.us/img819/4236/file5257.jpg)
(http://img684.imageshack.us/img684/4672/file5281.jpg)
(http://img810.imageshack.us/img810/6853/file6782.jpg)
si una de la noi
(http://img20.imageshack.us/img20/2865/file9792.jpg)
Si eu spun decat atat: HOT!!!!
Fiecare model Impreza a avut o editie limitata foarte foarte tare si pe oricare as conduce-o cu mandrie si cu bucurie. Nu se poate sa spui ca una este mai tare decat alta. Fiecare reprezinta modelul cel mai bine. Asta este concluzia la care am ajuns.
PS: Hai! Lasati pozele sa curga! Ce editii va mai plac? Eu mi-am adus aminte si de o alta preferata a mea, nu la fel de apreciata ca S204, dar pe aproape... RB320
(http://img80.imageshack.us/img80/4725/rb1ld2.jpg)
@malakay, putin off topic: Trebuie sa-ti dam niste flyere, sa-l aduci pe forum
din pacate vanez masina de 1 an si ceva nu am mai vazut-o :( si trec aproape zilnic pe strada aia ::)
hmmm.. o versiune peste care am dat din greseala. nici macar nu are nume
Poate nu la fel de aratos, dar la fel de potent ca toate editiile speciale. Ca tot mi-am luat bugeye ;D
(http://img262.imageshack.us/img262/2504/awesome01.jpg)
Wheelbase: 2540 mm
Track front: 1490 mm
Track rear: 1485 mm
Length: 4405 mm
Width: 1730 mm
Kerb weight: 1330 kg
Fuel capacity: 50 l
Code: EJ20
Type: 4-F
DOHC
4 valves per cylinder
Bore x stroke: 92.00 mm. × 75.00 mm.
Bore / stroke ratio: 1.22
Displacement: 1994 cc 121.68 cu in
Compression: 8
Fuel system: EFi
Aspiration: Turbo
Catalytic Converter: Y
Max. output: 319.3 PS (315 bph) (234.8 kW) @ 6400 rpm
Max. torque: 384 Nm (283.2 lbft) (39.1 kgm) @ 4400 rpm
Coolant: Water
Quote from: dan.pavel on June 30, 2010, 22:47:13 PM
nu ai cum sa il aduci pe dl victor baldescu pe un forum. e foarte ocupat si plus nu e de nasul nostru. nici nu ne nascusem unii dintre noi cind forja masini modificate de dinsul.
si preferata mea
(http://img841.imageshack.us/img841/7724/19488148412.th.jpg) (http://img841.imageshack.us/i/19488148412.jpg/)
Quote from: type_ra_555 on January 27, 2011, 22:55:01 PM
scuzati-ne dnl baldescu!
e cumva cu iz de misto postul tau. chiar nu e omul forumurilor, are pe la 55 ani
nu l-ai cunoscut pe Marcelutza....dar ma rog.era un fel de a spune ceva.
l-ai intrebat tu si a zis ca nu?
Ca sa inchei offtopicul l-au intrebat mai multi. Acum depinde de persoana. E drept ca cei care au fost la intalnire au vazut ca pasiunea nu cunoaste varsta. Oricum Marceluta e tinerel :)
Quote from: type_ra_555 on January 27, 2011, 22:57:33 PM
si preferata mea
man ala e un STI normal, din ce inteleg aici se vb de r205, spec c-uri, S-uri, Ra-R, 22b, P1 si alte fantezii, dar asta nu inseamna sa nu fie preferata ta in continuare :D
eu zic ca asta e ce trebuie!!
http://exchange.goo-net.com/usedcars/spread/700040242020101124001.html
Lista editiilor limitate Impreza Turbo
http://drischnie.homeip.net/www.subaru-impreza.de/SonderserienENG.htm#WRXSTiPD
BUN! pacat ca nu sunt si detaliile tehinice mentionate decat "putere mai mare si stabilitate imbunatatita"
Au mai facut Australienii un pachet pentru 300 modele:
(http://o.aolcdn.com/dims-global/dims3/GLOB/resize/620x412/quality/85/http://www.blogcdn.com/www.autoblog.com/media/2012/07/subaru-wrx-club-spec-11-1280.jpg)
Este un WRX cu 2-3 elemente STi. Va fi oferit fie in "tangerine orange", fie negru. La interior mici elemente care dau unicitate, cum ar fi o placuta cu numarul masinii 0-300, cusaturi portocalii la scaunele de piele etc.
Modelul se va numi WRX Club Spec 11.
in afara de culoare .........
Ceva frumos este in UK WR1 Blob eye fff tare masina , daruitati colea daca aveti lovea ceva de number one
http://www.ebay.co.uk/itm/160832859008?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1545wt_1185
Inca de vanzare !!!!
Eu ma ofer voluntar la programul spațial cu mașina aceasta , daca mai avea 2 aripi decola !!!!
2015 WRX STI Type S - http://www.4wheelsnews.com/2015-subaru-wrx-sti-type-s-breaks-cover-in-japan/
http://www.fhi.co.jp/english/contents/pdf_en_102443.pdf
2015 WRX S4 - http://www.4wheelsnews.com/2015-subaru-wrx-s4-becomes-official-in-japan/
bestii!
http://www.s22b.ru/impreza/2000p1.htm
O sora a 22B :) ,...
Prototip S207 in teste pe circuitul de la Suzuka
(http://s19.postimg.org/fr6s9enzn/988895_10152779546562621_86249_5503d0cdcfc65.jpg)
pfff ce baluta
Mda, se vorbeste de 2.0 DIT pe taxiul asta... sa vedem ce scot din el. Plus ca la cat au rigidizat sasiul pe generatia asta, sunt curios cu ce mai vin pe sub ea in plus fata de STi.
Doar in SUA pentru 2016.
SUBARU TO OFFER LIMITED EDITION SERIES.HYPERBLUE BRZ AND WRX STI MODELS
Limited to 700 WRX STI & 500 BRZ
BRZ receives upgraded SUBARU STARLINK® Multimedia
Rear Vision Camera now standard on BRZ
Exclusive Hyper Blue exterior paint and interior trims
(http://s19.postimg.org/sftcysj5f/subaru_hyperblue_brz_sti_001_1.jpg)
(http://s19.postimg.org/4rdv3imlv/subaru_hyperblue_brz_sti_002_1.jpg)
(http://s19.postimg.org/j9b2bidwz/subaru_hyperblue_brz_sti_003_1.jpg)
So much want!!! WRX STi NR4 (motor de 2.0)
(http://s19.postimg.org/5os3hqy2b/732851591969668964.jpg)
(http://s19.postimg.org/3zj09oicz/439641972423244538.jpg)
(http://s19.postimg.org/ulvgynmk3/8267258141346194244.jpg)
(http://s19.postimg.org/cgiikln1v/13726430581663891499.jpg)
(http://s19.postimg.org/vdy4xuqr7/19337372171301219217.jpg)
(http://s19.postimg.org/t83u3cnar/816621527287521208.jpg)
nu e bun. n ai loc de scaun de copil. ;D
da e nebunie mare acolo, iar acel ej207 e special rau de tot, si masina are un track pack optional in care primeste o volanta dichisita rau de tot, ar intra pusa mana pe o volanta din aia
WRX STI Type RA
2.5 turbo, 310 cai, evacuare revizuita, cold air intake, fibra de carbon pe unde s-a putut pentru reducerea greutatii (plafon, eleron, splitter), alt soft, treapta 3 revizuita, short throw shifter, monobloc 6 piston Brembo pe fata, jante pe 19 si ceva modificari la suspensie. Interesant ca este 2.5, desi in Japonia se merge pe 2.0 la toate editiile limitate de obicei. Eram invatati cu EJ207 de 320 cai.
ai uitat pistoane noi si alta harta Ecu (poate face rost Vali de ea :D ) mi se pare insa extrem de putin 310cp pt ce modificari are, eu am impresia ca nu zic cu adevarat puterea si pe dyno e mai mare.
Nu trebuie sa intelegeti ce spune, o sa va dati seama din ce arata el de niste dotari speciale. Cel mai tare mi se pare I/C Water Spay pus pe padelele din spatele volanului :D
https://www.webcartop.jp/2018/07/254098
RA-R 2018. Înțeleg ca au eliminat dotarile de confort inutile precum cruise, rezervor parbrizoil mai mic, motorul de pe S208 cu 329 cai pe 1490kg.
Diferenta intre sti si type ra 2018
http://www.comeanddriveit.com/engine/type-ra-vs-sti-internals
SUA primeste varianta S209
https://www.motor1.com/news/301060/2019-subaru-sti-s209-debut/amp/
Quote from: malakay on June 30, 2010, 22:15:42 PM
si una de la noi
100% 22B :)
Din pacate pozele de acum 13 ani nu mai sunt disponibile pe site-ul unde au fost incarcate :)
